Displays VLAN statistics at the port level.
| port_list | Specifies one or more ports or slots and ports. Can be one or more port numbers. May be in the form: 1, 2, 3-5, 1:*, 1:5, 1:6-1:8. |
| no-refresh | Specifies that there is no continuous refresh. The prompt comes back to the user after fetching statistics once. |
| refresh | Continuous refresh of output. |
N/A.
This command is used in conjunction with the configure ports [port_list|all] monitor vlanvlan_name {rx-only | tx-only} command.
The following command displays statistics for the ports 1-2 on node 5:
show ports 5:1-2 vlan stats Displays the vlan statistics in a real time countinous refresh mode or no-refresh mode. # show ports 5:1-2 vlan stat Port VLAN Statistics Wed Mar 28 10:52:59 2007 Port Vlan Rx Frames Rx Byte Tx Frame Tx Byte Count Count Count Count ================================================================================ 5:1 Default 318750522 20400046784 318750588 20400051672 5:2 Default 292811491 18739948736 292811975 18739980504 0->Clear Counters U->page up D->page down ESC->exit
For ports that do not support transmit statistics, a '-' will be displayed. For ports that do not support transmit byte counters, a '-' will be displayed for that row and column. Similarly, configuration using rx-only or tx-only will result in the display of “-”'s in the appropriate rows and columns.
This command was first available in ExtremeXOS 12.0.
The refresh keyword was added in ExtremeXOS 16.1.
